19" Wheels Help!
Old Mar 22, 2010 | 11:28 AM
JagXType620's Avatar
Default 19" Wheels Help!
I am considering in purchasing some 19" wheels.
The specs of the rims are:
Size19x8.5 Bolt Pattern5x108 Offset40
Would I run into any problems if I would put 235/35/19 Toyo Proxes 4 tires?
My stock wheels are 225/45/17...
Thanks!
Old Mar 22, 2010 | 01:31 PM
ufoz8mycow's Avatar
Are you on stock suspension or are you lowered?
Old Mar 22, 2010 | 03:35 PM
Stock suspension
Old Mar 22, 2010 | 05:18 PM
ufoz8mycow's Avatar
The fronts may rub slightly on your fender liner when turned at full lock but otherwise youll have clearance for miles.
If you do decide to lower the car (which you probably will once you realize how high it looks with 19s and a 4x4 stance) you will definitely need to roll fenders/possibly run narrower tires depending on what you go with.
Old Mar 23, 2010 | 01:39 PM
gotti15's Avatar
I'm running my 19x8 wheels with 40mm offset and hubcentric rings on 215/35/19 General Exclaim Tires and stock suspension. I had 225/35/19 on there but it rubbed like crazy. The 215/35/19's dont rub at all; the only time it did is when I hit a pothole. Hope this helps
Old Mar 24, 2010 | 04:07 AM
exexpat's Avatar
Thanks!
You'll want 225/35/19 with a 40mm offset (assuming fender rolling won't happen). There is no real difference in ride, performance or curb protection from a 225 to a 235.
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
scooternva
19
Oct 27, 2015 02:14 PM
DustysSon
Sep 13, 2015 04:17 AM
lickahotskillet
Sep 11, 2015 07:54 PM
