2002 x type fuel pump
Old Nov 24, 2009 | 09:32 AM
ktech23's Avatar
Default 2002 x type fuel pump
continuiation from my previous post, My car recently died on the highway and i have been making efforts to diagnose it for weeks.
when i spray starter fluid in the intake it starts for a second.
so i guess i have to replace the fuel pump.
any leads on where i can obtain one cheaply?
thanks in advance
Old Nov 24, 2009 | 08:25 PM
afonda's Avatar
Default might try this.
http://www.jaguarparts.com/
Old Nov 25, 2009 | 12:50 PM
jimmy's Avatar
ud
The test for a fuel pump is definetly not spraying something in the intake.
Check if there is flow, and also check pressure.
Maybe something as simple as a broken fuse or wire, the roll over switch is tripped,
maybe, the computer has decided not to fire the injectors?
Fuel pump is expensive and a big job ot replace.
do some logical trouble shooting my man...
Old Nov 25, 2009 | 01:45 PM
Brutal's Avatar
Originally Posted by jimmy
the test for a fuel pump is definetly not spraying something in the intake.
Do some logical trouble shooting my man...
while all possible causes, if you worked on these all day, you would not complicate the diagnosis with things that are extremely unlikely considering the pumps go so frequently, and spraying the intake while doesnt condem the fuel pump per sey, it does tell you the engine has fire and capable of running if you add the missing component...in this case fuel....i have 2 wanting for new pumps right now(backordered) but hey, if you want to spend the time to be sure of where you started................no problem here
fast40driver
Apr 19, 2024 07:24 AM
h4wk
Nov 27, 2015 05:10 PM
convincor
Sep 3, 2015 08:03 PM
bluerdg
Sep 1, 2015 08:07 AM
BigD
Aug 31, 2015 06:13 AM
