2004 Jaguar X-Type 3.0L V6
The check engine light is on. Checking for the codes doing the scan in Auto Zone: the code is P2057. Could some one tell, what this code stands for? The help would be greatly appreciated.
Thank you!
Thank you!
Ryan, doing a little bit of research, you have a problem with one of your injectors (bank 2 specifically) that is starting to short out, leading to a low resistance on that circuit. This can be simply an injector failing, but it could also be a wiring issue too. Unless you are familiar with wiring, it might be something you want to take to a shop to have looked at.
Since the coolant level was too low, the hood was opened to look for the source of the radiator fluid leak, in the process we heard a hissing sound from the check valve in line with the break booster vacuum line. The mentioned valve was rotated and we saw a sort of tiny hole, we went to auto zone and advance auto parts and Napa they did not have the appropriate check valve, so we used epoxy to seal the hole, and also fully coated the valve. We waited for the coat to harden (about 5 minutes) then turned the car on. The check engine light went off. Also was checked for any code, but there was no code. Hope this helps!
Since the coolant level was too low, the hood was opened to look for the source of the radiator fluid leak, in the process we heard a hissing sound from the check valve in line with the break booster vacuum line. The mentioned valve was rotated and we saw a sort of tiny hole, we went to auto zone and advance auto parts and Napa they did not have the appropriate check valve, so we used epoxy to seal the hole, and also fully coated the valve. We waited for the coat to harden (about 5 minutes) then turned the car on. The check engine light went off. Also was checked for any code, but there was no code. I just ordered for a booster vacuum hose online at amazon.
X_Type_South_Africa
Dec 9, 2015 05:37 PM
Aranon
Sep 1, 2015 01:00 PM
Dion Petty
Aug 30, 2015 01:00 PM
