3.0L - Misses while idling ...
Old Dec 30, 2014 | 08:46 AM
Cessna424's Avatar
Default 3.0L - Misses while idling ...
I have an 04 XType 3.0L with 140,000 miles. While it runs flawlessly at speed, it has started to "stumble" while idling. It acts like it will stall then recovers and runs fine. It was intermittent but now has become pretty regular. Any ideas?
Old Dec 30, 2014 | 10:55 AM
astromorg's Avatar
Most likely possibility might is a throttle body fault - is the butterfly sticking around the idle position?
Old Dec 31, 2014 | 04:04 PM
Cessna424's Avatar
Astromorg, I presume the Throttle Body can be cleaned with a quality Throttle Body cleaner/spray? If so, I'll give that a try this weekend. Thanks!
Old Dec 31, 2014 | 04:40 PM
astromorg's Avatar
Yes, but be gentle! The throttle body bore has a special molybdenum coating that can be damaged by over vigorous rubbing!
Also, check out this post
https://www.jaguarforums.com/forum/x...estion-133871/
pilot435
Apr 8, 2016 06:16 PM
Thang Nguyen
Oct 12, 2015 01:25 AM
NTL1991
XJ40 ( XJ81 )
Sep 20, 2015 06:22 PM
ccfulton
Sep 20, 2015 05:15 PM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
