3d printable fix for recirc motor
Old Aug 11, 2024 | 01:01 AM
Telewubby's Avatar
Default 3d printable fix for recirc motor
My cars recirc door got stripped out just like almost every other xtypes, I didn't like the fix jag gave with tsb #x-t412-02 due to the fact it's a permanent attachment so I made these 3d printable models that add a spacer in between the motor and housing a spacer you can glue into the door then slide the motor into the spacer so you can replace the motor at a later date. I printed it out of asa and it held up to 100f days, I used a pair of wire cutters and cut a longer 2' #8 metal screw and pressed the shaft spacer into the door.
link the model here, https://www.thingiverse.com/thing:6726623
Old Aug 11, 2024 | 10:08 AM
dh53's Avatar
Nice work. Thanks for posting the files open source to help others.
Old Aug 12, 2024 | 11:39 AM
Dell Gailey's Avatar
Held up to 100f days or HAS held up to 100f days?
Old Aug 12, 2024 | 02:34 PM
Telewubby's Avatar
it’s been fine with no damage at 100F outside temp. Glass transition of asa is 100-112C so it should be fine up untill 100c
J444thn
Jan 13, 2022 06:25 PM
animesis
Jan 4, 2022 05:44 PM
JensenHealey
XJ40 ( XJ81 )
Jan 15, 2020 09:35 AM
04xtype04
Feb 18, 2014 10:02 AM
