AC issues 2004 x-type
Old Nov 12, 2017 | 05:06 PM
Brandiheritage's Avatar
Default AC issues 2004 x-type
I've got an 04 x-type and every time I turn the AC on the car dies....I could be going down the highway or sitting at a light and it still does it.... Any suggestions on what it could be.... Car runs great when the AC is off
Old Nov 13, 2017 | 03:26 AM
Mark Murphy's Avatar
Use a multimeter and check volts as you turn on the a/c, if it drops, its electrical, could be wiring to the clutch, or a/c pressure sensor. if not, maybe a seizing compressor (not likely)
Old Nov 14, 2017 | 08:47 PM
Thang Nguyen's Avatar
It could be a seizing compressor shaft, when you turn the AC on the clutch engaged the the pulley the engine could not pull the compressor so it die.
