Alternator swap
Old May 20, 2024 | 12:50 PM
Mr rx-7 tt's Avatar
Default Alternator swap
Can the alternator be replaced without taking off the A/C compressor?
I'm getting ready to do the A/C so I may change the alternator thus the question.
Thanks in advance.
Old May 21, 2024 | 11:20 AM
Mr rx-7 tt's Avatar
Alternator works fine but if you have to pull the A/C compressor to replace the alternator I may do it now as the car has 121,000 miles on it???
If not I will just replace the A/C compressor.
Old May 21, 2024 | 12:30 PM
Thermo's Avatar
Veteran: Navy
RX-7 tt, I would not worry about the alternator. Worst case, pull the alternator out of the car, get it in your hands and give it a good once over (blow out the dust from inside the alternator, clean up the main terminal on the back, ensure the plug area has silvery pins in it, maybe even apply a little bit of full synthetic oil to the bearings). This way, when you put it back in, you are guaranteed to have something that will last a long time. Alternators in these cars are pretty good and to have an alternator fail is an unusual thing.
Old May 21, 2024 | 04:14 PM
Mr rx-7 tt's Avatar
I can get it rebuilt in town here for a good price so I'll probably pull and check it to see if the brushes and bearings are in good shape. I wonder how long the original alternators usually last?
Thanks for the feed back.
ericeric7
Jan 9, 2026 01:46 PM
John-Melanie
Jan 8, 2026 02:59 PM
petemohr
May 6, 2020 02:40 PM
orangeblossom
Apr 21, 2017 01:30 PM
