Another air con issue...
Old Oct 15, 2017 | 03:17 AM
RichXT's Avatar
Default Another air con issue...
Hi all. I have recently had a replacement air con compressor fitted by a reputable jag technician. The system was regassed and the air con switch can be heard engaging the clutch. All the mechanical side of the system appears to be working as it should and nothing is leaking. However I have no cold air! Any ideas as to what to check next?
Old Oct 15, 2017 | 06:19 AM
Welcome to the forum RichXT,
Here's the bullet point checklist from JTIS:
Some you've already checked and eliminated but flaps or fuses could be the cause.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Oct 15, 2017 | 08:23 PM
Thang Nguyen's Avatar
If you have it work by a "reputable Jag. tech." and you have no cold air, then you should take it back to the place to have them check it again to see what's wrong.
