ATF Leak
Old May 14, 2024 | 04:35 PM
Gdt928's Avatar
Default ATF Leak
Hello all, my 2003 X-Type 2.5 with 156,000 miles has developed an ATF leak. I had the fluid changed approximately 6 weeks ago, and would like to know if there are common areas where leaks occur and if so what are the fixes. Thank you in advance!
Old May 15, 2024 | 11:33 AM
astromorg's Avatar
Problem with autobox just after a fluid change is maybe not just a coincidence
Was the fluid change done properly? - that is, was the level checked at the correct temperature, with the engine running and with the 'box in N?
Was the level plug in the base of the 'box used?
Maybe it's been overfilled and venting the excess off?
Mandybxk8
Jul 25, 2023 04:01 AM
XtypeHI
Sep 24, 2019 07:47 PM
mzs_biteme
Aug 18, 2011 10:09 AM
climberman
May 9, 2011 09:46 PM
jimmycruz99xjr
Feb 1, 2011 11:01 AM
