Autolight
Old May 8, 2023 | 09:06 AM
TheLasombra's Avatar
Default Autolight
Hello everyone and forgive my bad English, I have an Xtype 2003 executive 2.5 I got the Automatic light selector from a demolished xtype, I have the electrochromic mirror from the factory how do I make the lights work automatically? (my original one did not have factory) thank you allù
by Lasombra
Old May 8, 2023 | 04:27 PM
Thermo's Avatar
Veteran: Navy
Allu, the switch is only half of the circuit needed to make the headlights turn on automatically. You also need a sensor to tell the circuit to activate. This would be located in the center of the dash, up near where the windshield touches the dash. The sensor is a small black ball that measures how bright it is outside. You need to install that piece too. This will most likely involve you having to remove the radio to get to where this sensor can be fitted into the dash. Then you will need to find the plug for the sensor which is going to be tucked away with a jumper piece in it. Where exactly you will find that is hard to say. BUt, it should be in the general area behind the radio. Granted, it is possible that your car was not wired with this additional wiring, which will make this much harder to to make functional as you will have to start cutting wiring and adding to the wiring harness.
Old May 9, 2023 | 07:20 AM
many thanks for your kindness in answering me, now I ask you if by chance you have some example photos so I can easily identify, and if you tell me the name of the sensor I will buy it
drossy007
Nov 1, 2021 12:52 PM
XJag19
Aug 15, 2018 10:46 AM
JL030511
Feb 23, 2015 10:42 PM
