B1852?
Old Mar 7, 2018 | 11:53 AM
Rogelio Serrano's Avatar
Default B1852?
I am using an x431 creader 8 and the engine scan shows p1852 and b1852. EOBD scan only shows p1000.
What is b1852? I cannot clear that dtc. Is it something that would block evap leak test from running? It has been inc for a while and I have done 2000 miles. I noticed that filling up keep stopping and I have to pull out the nozzle a bit to keep it going.
Old Mar 7, 2018 | 12:43 PM
jaguarxjordan's Avatar
i think but not sure that B1852 is a Climate Control Temperature Differential Circuit Short To Ground .
Old Mar 7, 2018 | 03:14 PM
avern1's Avatar
I would recommend that you check the codes again using a different scanner. The Jaguar shop manual doesn't list either of the codes you are getting. Not all readers work well with Jaguars.
Old Mar 7, 2018 | 04:53 PM
Alfadude's Avatar
Are you sure it isn't P1582? If so, that is a Flight Data Recorder" stored data code. That just means that info was stored and it does not have any kind of warning and the check engine light would not go on.
