Battery cable temperature readings
Old Feb 11, 2023 | 07:32 PM
Clackavosticus's Avatar
Default Battery cable temperature readings
Two years ago I changed my positive battery cable as it was getting hot. Lately I have been getting a battery light come on in high revs when accelerating hard (it stays off the rest of the time) and I suspect maybe I might need to change the negative cable.
I have a IR thermometer on order with ebay so I can take accurate temperature measurements. Would anyone be able to confirm the following regarding cable / battery terminal temps
1. What a "normal" Working temperature would be in the range of?
2. What a high resistance, defective, cable temperature would be in the range of where it would be necessary to change the cable?
Old Feb 12, 2023 | 08:57 AM
Thermo's Avatar
Veteran: Navy
Clack, I would say that if your wiring is working properly, you should be within say 10 degrees Celcius of the surrounding temps. So, measure the cable, then measure a support in the area. the 2 read within 10C of each other, probably good.
The other check you can do is using a multimeter, put 1 end of the multimeter on the engine block with the other on the lead of the negative battery terminal (do not touch the clamp of the battery cable). Have a second person start the car and rev the engine up to near redline (preferable to do this with the engine up at temp). If the multimeter goes above 1.0 VDC, then you have an issue. I would personally use a 0.5 VDC standard, but the world standard is 1.0 VDC.
Barry_Tucker
Sep 25, 2022 01:53 AM
BlownKitty
Apr 19, 2021 12:21 PM
jrdelohery
Jul 23, 2020 04:26 PM
sov211
Sep 4, 2017 03:36 PM
OWRltd
Nov 4, 2013 02:22 PM
