BRAKE BLEEDING with JLR-SDD
Old Sep 17, 2017 | 01:40 PM
BradsJag's Avatar
Default BRAKE BLEEDING with JLR-SDD
HI everyone.
Sorry to be asking another question so soon after my last one.
Could someone please tell me if it is possible to cycle the ABS pump\module using SDD v130 ?
I recently replaced all the brake components (discs, calipers, pads and hoses) inc 2 rear brake pipes.
Front calipers bled a treat, so no problems there.
Tried bleeding rear calipers, fluid came out of the nipple and stopped within 2" of the nipple inside the bleed tube.
This happened on both sides.
I assume therefore that there may be an airlock in the ABS module. I tried bleeding the ABS but no air appeared.
I'm sure I saw somewhere that you can use SDD to cycle the ABS to bleed the rear brakes.
I can't run the car around as it has no current MOT.
I have a Mongoose and JLR-SDD but can't find the section for brake bleeding.
Can anyone help ?
Old Sep 18, 2017 | 11:28 AM
Dell Gailey's Avatar
The Carsoft i930 says on their website (for Landrover w/free addes Jaguar one) that it allows you to cycle ABS.
Old Sep 18, 2017 | 01:40 PM
BradsJag's Avatar
WOW, that's really handy, I happen to have one of those i930's. I've not used it since getting JLR-SDD.
I'll check that as soon as I can.
Many thanks for that.
Brad
