Brakes will not bleed
Old Jul 16, 2016 | 04:46 AM
Papot001's Avatar
Default Brakes will not bleed
I went to change my brake pads, realized that the rear calipers had ceased so I purchased new ones. Now my brakes will not bleed, no pressure in the lines. Can someone please advise on what to do. Thanks
2005 X-Type (added by GGG)
Old Jul 16, 2016 | 05:53 AM
Welcome to the forum Philip,
I've moved this question from your Intro thread to X-Type forum. Members here with the same model will be able to help.
Old Jul 16, 2016 | 08:05 AM
swingwing's Avatar
Were the (front) brakes working before you started this job? What method are you using to bleed? A pressure bleeder may help; recommend you bleed the front brakes while you're at it.
Old Jul 16, 2016 | 02:21 PM
Papot001's Avatar
So I used your method, it worked and I appreciate your help. But another problem came up, all four brakes are locking up. I drained the brakes fluid and refilled it back up but the brakes are still locking up
80sRule
May 30, 2016 05:45 PM
Adam Lueb
May 3, 2016 07:56 PM
orangeblossom
Apr 27, 2016 01:39 AM
benpearce2013
Apr 25, 2016 08:49 PM
jeffn
22
Apr 20, 2016 11:46 AM
