Can '04 rear rotors be turned?
Old Jun 22, 2008 | 05:59 PM
H20boy's Avatar
Default RE: Can '04 rear rotors be turned?
Tough to say if the rotors needed turned w/o getting a thickness tested on them. Sure they can (I think someone around here said the S-type Rs are not recommended to be turned, only replaced) and only 40k miles, I think if slightly warped, a good turning would have cured your vibration in the brake pedal. Rears just don't get the wear that the front does. Also, if the rear caliper wasn't releasing, simply putting new rotors and pads wont fix that issue, could need a new caliper kit, or perhaps just lubricated in all the right places. I would be mad that you asked for the old parts and they could not show them to you. I'm sure that's not the first time they've been asked that.
Did they do both front and rear, or just make rear repairs? If only the rears, I would suggest getting the fronts turned (like an NTB or something) and see if that fixes your uneasy vibration.
Old Jun 28, 2008 | 11:51 AM
FactoryJaguarTech's Avatar
At the dealer, they only come as a set, so you got both replaced.
Old Jun 28, 2008 | 02:19 PM
Jagtech's Avatar
Jaguar does notturn rotors. Jaguaralways wants new rotor and pads installed.Jaguar rotors are a soft metal. Thats why when its time for brake, the rotors have a very nice traper edge. The problem on 02-04 there wasn't silders. The brake just seat on the caliper mount so after time from brake dust, salt, and sand the brake pads will stop moving, which will cause thecaliper to not return. For 5 years i never had to replace rear cailpers on a x-tpe
Old Jun 28, 2008 | 10:57 PM
Dennis's Avatar
ud
Good advise there guys..I changed my Rotors when I did my Pads..EBC sport rotors are way better thanOE Rotors...
JarodL
Mar 7, 2024 01:39 AM
mbergen
Oct 23, 2019 10:26 PM
jdzubas
Oct 4, 2015 09:14 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
King Charles
Sep 3, 2015 12:40 AM
