Clutch goes to floor wont shift or start.
Old Jan 2, 2017 | 04:43 PM
bknox78's Avatar
Default Clutch goes to floor wont shift or start.
I have a 2004 X-type 2.5 I was driving the other day and my clutch went to floor and wouldnt shift. I had it towed home but I dont know how to diagnose it. I just had a new clutch installed less than a year ago. I heard it is probably the master or slave cylinder. How can I tell what the problem is or which one needs replaced?
Old Jan 3, 2017 | 10:46 AM
swingwing's Avatar
I'd first try to find which component was leaking. Was either replaced along with the clutch job a year ago? If not, I'd be inclined to replacing both cylinders; I wouldn't want to replace just one, then have the other one fail shortly thereafter because it becomes worn out as well. Then you have to repair same system and re-bleed both cylinders. Part number for master cylinder is C2S41449 ($147 @ SNG Barratt), slave C2S46903 ($186 @ SNG Barratt). Rock Auto has multiple pricing options for both parts, and you can query eBay and other vendors for their offerings. Post outcome on this thread, OK?
Old Jan 11, 2017 | 11:15 AM
DaveJessop's Avatar
I agree it's probably best to replace both master and slave at the same time - they are not too expensive and will work out a lot cheaper in the long run than paying for two separate jobs
Old Feb 1, 2017 | 02:16 PM
bknox78's Avatar
Thank you guys. They are replaced now. Where is the clutch bleeder valve located?
