Code P1603 2003 X-Type 3.0L
Old Sep 6, 2018 | 06:52 PM
vkng7's Avatar
Default Code P1603 2003 X-Type 3.0L
Cannot select any gear, cannot select park while engine running without gear crashing noise!
PO 1603 and Gearbox fault light illuminated
All above happened when battery failed.
Anyone have similar occurrence and remedy?
Thank you.
Old Sep 7, 2018 | 10:08 AM
S-Type Owner's Avatar
Thank you.
Hi, Vkng7:
Your have posted the above in a classics forum dedicated to the full size saloons of the 1950s and 1960s. Traffic here is limited and DTCs were unheard of at the time these cars were produced; so, I suspect that you will find little in the way of assistance on this particular forum.
I would, however, suggest that you re-post your question here:
https://www.jaguarforums.com/forum/x-type-x400-14/
Good luck in resolving your issue!
Old Sep 7, 2018 | 04:02 PM
Cannot select any gear ......
Welcome AGAIN to the forum vkng7,
I've moved your question from Mark V - X 420G (1948 - 1970) to X-Type forum. Members here with the same model will be able to help.
If you had shown the courtesy to react to my previous request to post an Intro, you would have received some useful advice on posting and avoided this mis-post.
Old Sep 9, 2018 | 08:47 PM
vkng7's Avatar
Greetings Super Mod,
I do apologize for mistakenly posting in the wrong Forum. This was simply clicking the wrong one in haste.
With regard to Intro is a must, you will see I am not a new member.
For clarification, do I need to do an intro for each subject post?
If so I again apologize for not adhering to this.
solidx
Feb 22, 2018 05:14 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
sjuraud
Aug 28, 2010 02:11 PM
Wolfmiester
Nov 5, 2006 12:10 PM
Feb 14, 2006 10:17 PM
