Coolant leak @ TB cause lean code?
Old Dec 25, 2014 | 02:32 PM
innzane's Avatar
Default Coolant leak @ TB cause lean code?
I am losing small amount of coolant over time.
I have both lean codes.
I done most of the vacuum leak repairs, smoked it.
No signs of coolant leaking, no smells.
Only smoke showed around throttle body.
Is there any way the coolant could be leaking from the
contraption under the TB and into the TB causing a lean condition?
And that is why I find no leaks, I thought worth asking.
Old Dec 25, 2014 | 09:48 PM
Thermo's Avatar
Veteran: Navy
I would be placing money that you are going to find a rip in the bot on the front of the throttlebody. There are no other likely leak points on the throttlebody. The only other possibility is the o-ring on the downstream side of the throttlebody.
Old Dec 26, 2014 | 10:42 AM
Brutal's Avatar
The shafts in the tb leaks too when they get older worn, and no on coolant causing lean codes
Old Dec 27, 2014 | 08:55 AM
innzane's Avatar
Ok, I figured a long shot, but that is where my luck hangs.
Rivguy
Dec 4, 2020 07:55 AM
OkieTim
Sep 8, 2015 04:48 PM
Xkr x100
Sep 6, 2015 08:50 AM
OkieTim
Sep 2, 2015 12:48 PM
