Dice install 2007 xk
Old Mar 2, 2012 | 07:27 AM
Johnj's Avatar
Default Dice install 2007 xk
I am contemplating installing a dice electronics universal rds module so I can use my iPhone/iPod. 2 questions: does anyone have experience with this unit and do you know if I will need an antenna adapter. The module uses a standard 1 pin connector.
Thanks!
Old Mar 7, 2012 | 06:19 AM
jmarshall's Avatar
Yes, Antenna adaptor is required. sometimes it happens that it may not come with the kit you bought but its necessary so buy separately.
For the procedure,
first remove the battery cable connections and then remove out radio from the car.
Set the DIP switches for the frequency selector switch to the desired setting.
Install RDS cable and then plug in the radio antenna to the module receptacle.
Then put the radio in its place and connect the battery cable.
Set the frequency on the radio you want
Old Mar 8, 2012 | 09:43 AM
Johnj's Avatar
Thank you!
Any idea on the type of antenna adapter. I have looked at a number of sites and no one ( that I could find ) lists any adapter for the jag.. I can believe that they used a standard connector. I'm just trying to get everything in place before I take the console apart.
Thanks for the help!
Old Mar 9, 2012 | 08:38 AM
Bruce in North Dakota's Avatar
From: That Rectangular Hole in the Consciousness of America
When I read the thread title "Dice Install", I had to click.
I thought you were talking about hanging those fuzzy dice from the rear-view mirror.
Old Mar 9, 2012 | 09:36 AM
billbjork's Avatar
Default Dice
So did I think of the mirror hanging dice,must be a 60s thing!
Old Mar 9, 2012 | 10:16 AM
Me too.
captbob73
Oct 24, 2015 05:49 PM
'05 Gold XJ8L VDP
Sep 18, 2015 07:15 AM
ferraripete
Sep 10, 2015 01:24 AM
SCMike
Sep 9, 2015 09:30 AM
mcdutch
Sep 4, 2015 03:38 AM
