Driveshaft
Old May 10, 2016 | 11:46 AM
jmott's Avatar
Default Driveshaft
I am looking for a part and not sure what you call it. On a standard truck where the driveline hooks to the rear end its called a u-joint. On the Jag there are 6 bolts that hold the driveshaft to the rear end. I have damaged that metal ring and the dust seal and need to replace it. I removed the driveshaft. There is a clip that holds that piece on and I have the piece off. Can I buy that piece and the dust seal or do I need to replace the entire driveshaft?
Jason
Old May 10, 2016 | 08:22 PM
avern1's Avatar
Attached is the parts breakdown from the SNG Barratt catalog. You can download it for free by clicking on their advertising header.
File Type: doc
Old Aug 16, 2016 | 03:17 AM
hahebure's Avatar
I am having the same issue (ext50/51)with my 2006XJ. I need the file to burn to DVD to boot. Please send it to me if you have it, I would really appreciate it. Thanks.
