Engine light codes
Old Nov 28, 2009 | 03:21 PM
Mago304's Avatar
Default Engine light codes
I just got a couple of engine light codes. Autozone didnt have read out for jags. Does anyone know what p1111 and p0037 codes mean?
Old Nov 28, 2009 | 05:07 PM
Cadillac's Avatar
Here you go :
  • P1111 - Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
    • P0037 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 2
Old Nov 29, 2009 | 02:42 PM
Teck4Jag's Avatar
you have rats,check the connector on top of the intake manifold
Old Nov 30, 2009 | 03:26 PM
BuckMR2's Avatar
P1111 is normal.Every X Type will have this code.
It isnt an error its just a code to let you know that the system had performed all its checks successfully between turning the key from position II to starting.
Nothing to do with the Intake Air Temp Circuit
philwarner
Dec 6, 2021 07:13 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
big d
Sep 3, 2015 07:37 PM
Jandreu
Aug 29, 2015 07:31 PM
daro31
Aug 27, 2015 09:26 AM
