Head light auto leveling not working
I can anyone help I recently had my front shockers replaced and now my head lights don't self level. They are stuck in the up position. My car is a 04 2.0d sport
Ants, it sounds like when they did the shock replacement, they forgot to reconnect your level sensors and now the car thinks that the front end of your car is really low (hence why the headlights are shining upwards). If you look behind the front tires, you should see a small black plastic piece with a small arm that is hanging down on each side. In the general area, you should see a place to attach the end of the arm. That should get you back where you need to be.
Ants, did you look at the other side? There are 2 sensors in the front of the car for the headlights. Then you need to also look at the rear of the car and see if the 1 sensor there is connected. If all those are good, then we may be looking at a bad headlight leveling control module. It is located inside the passenger compartment on the left side, behind the plastic cover at your feet.
Ants, look on your passenger side (driver's side for the US folks) and look back in near the joint for the main arm that has the support for the coil spring. You will see the height sensor there about 6" (15 CM) from the inner joint.
X_Type_South_Africa
Dec 9, 2015 05:37 PM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
Oct 19, 2015 09:44 PM
