Heater Core Replacement
Old Feb 20, 2015 | 12:35 PM
Kiknazz's Avatar
Default Heater Core Replacement
Has anyone replaced a heater core in a 2004 3.0 x-type?
Need any help that you can give. The core is leaking antifreeze out the drain hose.
Thanx
Rick
Old Feb 20, 2015 | 01:26 PM
Thermo's Avatar
Veteran: Navy
Kik, in short, you are going to end up removing the whole dash to get at the heater core. Wish there was a better answer, but that is the short of it. i am not aware of a way to pull it out the side or something like that.
Old Feb 21, 2015 | 11:24 AM
Dr dome's Avatar
Its a pain but Chris is right Almost the whole dash will need to come apart to remove the core.
Sorry for the bad news.
Good Luck,
The Dr!
Old Feb 22, 2015 | 08:45 AM
Kiknazz's Avatar
Default Heater Core Hose Size
I guess for now I will need to bypass the heater core with a new hose. Anyone know what size the hose should be and will it need to be a different size at each end?
Thanx Rick
Forcedair1
Sep 8, 2025 01:57 PM
KarimPA
Sep 12, 2015 08:15 AM
edtexas
Sep 5, 2015 10:49 AM
pocketrocket
Sep 3, 2015 07:44 PM
KarimPA
Sep 3, 2015 07:32 PM
