heater only working sometimes
Old Nov 29, 2020 | 06:29 AM
X(Y)-Type:unsolved's Avatar
Default heater only working sometimes
I have a strange problem with my heater. The car is a 2006 X-Type with the 2.0 Diesel motor. The problem: when I drive the car, the heater only blows cold air. after I drive for about 10 to 15 minutes, I must stop, wait a few minutes and restart the engine. Then the heater works normally, until I park the car for a few hours. If I drive off after 2 or 3 hours, everything is fine. but if I wait - lets say - overnight, the same problem starts again. Now, the car always took very long to start heating, usually ca. 15 minutes or 5 miles driving. It bothered me very little since I hardly ever drove the car in winter. But things have changed and I need the car sometimes when it is cold outside. I have replaced the thermostat, checked the coolant level, even disconnected the radiator fans. Nothing makes the problem go away! What am I missing? I would appreciate any help greatly, thanks in advance!
this is the patient
Old Nov 30, 2020 | 11:52 AM
Jo van Haag's Avatar
It looks as if the thermostat no longer works. The temperature display should no longer show the usual value, i.e. the middle position. Location Austria, district of Melk?
Old Dec 2, 2020 | 03:12 AM
Hi Jo! Yes, that was also my first thought. Unfortunately, the replacement of the thermostat brought no change. If anything, it got worst ! About my location: yes you're right, it is the District of Melk in Austria! This is my birthplace but I lived in the US for nearly 30 years. Van Haag sounds rather German or Dutch. Are you in Europe?
Old Dec 2, 2020 | 11:03 AM
JagXtypeV63.0L's Avatar
My best guess would be a clogged heater core, sometimes you can do a reverse flush to clear it.
Hope this helps-Andrew
Old Dec 4, 2020 | 02:17 AM
Well, that would be a possibility, but it would not explain why the heater works normal after a shutdown and restart of the engine. Or am I missing something? I noticed another phenomena today: when I leave the heater switched to "windshield defrost", it works without the shutdown/restart. At least, that what happened yesterday morning. This car has a live of its own it seems, but there got to be a way to fix this annoying problem. The Jag dealer would probably replace countless parts for countless Euros, with or without results. This is not in the budget! I got to find and fix this on my own......
Old Dec 4, 2020 | 02:21 AM
Forgot to mention: it works only if the "Defrost" is still on from the day before, simply switching it on after startup is not helping either.
psg
Jan 5, 2013 11:53 AM
pan84
Sep 11, 2011 11:26 PM
raymondo226
XJ40 ( XJ81 )
Apr 4, 2011 05:21 PM
Jaguar9891
17
Nov 5, 2009 12:29 PM
