Help with some codes
Old Dec 11, 2020 | 07:59 PM
DocMitchell's Avatar
Default Help with some codes
​​​​​​Hello all. I'm new here. Just bought the car a few weeks ago and I'm loving it!
I have had a few issues. When I got it, it was misfiring on 1,3 and 5. I have since fixed that by replacing coil packs and spark plugs, and also did valve cover gaskets while I was in there. I also replaced all vacuum lines and the check valve. So that issue was fixed. Now my new issue is that I'm getting these codes (see attached). The car runs and drive perfectly unless I let it sit at idle too long (like in a drive through) then when I take off it won't go above 3000rpm. It usually only lasts through 1st and 2nd gear then it clears itself up. Any suggestions from you professionals?
Thanks in advance!
jaguar0206
Dec 8, 2019 07:43 PM
SynySTR
Oct 17, 2014 09:33 AM
bassman64
Apr 20, 2014 04:25 PM
XTypeJagMan
Feb 28, 2014 08:38 AM
afonda
Nov 3, 2009 06:58 PM
