I need a new 2003 Xtype catalytic converter:(
Old Jan 7, 2013 | 07:45 PM
cujet's Avatar
If you try the citric acid cleaning method:
1) do it off the car
2) heat the solution to 80 degrees C and keep the temperature there.
3) agitate occasionally
Old Jan 7, 2013 | 08:12 PM
tjandy's Avatar
I have several codes
P0301
p1313
p0420
p1603
p1260
p1571
p1582
p1629
Can someone tell me if this tells me which one is bad?
Old Jan 10, 2013 | 11:00 PM
Jeeves12's Avatar
Curious, did the Jaguar dealership tell you, if anything else was wrong with car? I heard and thought there were some other posts stating CATs just don't go bad there's a reason behind the failure. Therefore, the root problem should be fixed first, otherwise the new CAT could fall prey to the same problem. Just a thought.
Old Oct 31, 2013 | 02:48 PM
harvey_birdman's Avatar
Anyone have any luck removing the rear/passenger cat without dropping the subframe? Some details would be appreciated.
Old Nov 1, 2013 | 07:10 PM
Dr dome's Avatar
Birdman,
I have replaced 2 of those cats. Easiest that I found was to take it out through the pass side wheel well. you do have to drop the sub frame and remove the rack bolts giving you room to pull out the cat. I also removed the intake for ease of removing the bolts on the header.
Good luck,
The Dr!
Old Feb 22, 2016 | 01:15 AM
Paul Silva's Avatar
Default Help with used Catalytic converter
Hi, do you still have used cat con for a 2003 Jaguar X type 2.5 ?
Thanks for any help you can provide
Paul Silva
Psilva70@yahoo.com
QUOTE=albackuk;445126]HI Preze
i will have them as of january they are second hand but are removed from cars dismanteled speciically for parts.
Im not sure of the us shipping cost but its certainly not going to be anywhere near dealer prices.
If you need help let me know
alex[/QUOTE]
Old Feb 22, 2016 | 06:07 PM
chiefM's Avatar
Rock Auto $174 to $197 dollars. I have never had an issue with one single part I have bought and used from them. I just bought a COP and it was flawless and 28 bucks shipped.
Old Feb 28, 2016 | 01:50 PM
  #28
bowhunter72's Avatar
Auto parts warehouse.com
Got front cat for about $175.
Rear I think is about $300.
Changed front cat on ramps in an hour,rear cat will require a lift I've been told.
Old Feb 14, 2017 | 11:40 PM
Jacki747's Avatar
I am in Queensland Australia and I need a catalytic converter for my x type 2.1 2004 Jaguar any idea where I can buy a second hand one
Old Feb 15, 2017 | 08:41 AM
  #30
Dr dome's Avatar
i might be able to get you one. Is it the front of the car or the back one next to the firewall?
send me a email. Jciamprone@gmail.com
i will see what i can do
Msteiner
May 16, 2016 12:19 AM
Finbarr1975
Oct 4, 2015 05:32 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
jospolice
Oct 1, 2015 07:52 AM
millertic
Sep 30, 2015 08:11 PM
