Input on OBD readings
Old Mar 13, 2018 | 08:23 PM
Dell Gailey's Avatar
Default Input on OBD readings
This is an area I have no experience in. Attaching an OBD CSV (comma separated value) log on 150 mile round trip. Any input appreciated.
File Type: csv
Old Mar 13, 2018 | 09:06 PM
JBzXJ40's Avatar
It opens up in Excel, I see you're looking at fuel trim data..... are you chasing lean/rich DTC's?
Old Mar 13, 2018 | 09:45 PM
Thermo's Avatar
Veteran: Navy
Dell, what are you trying to figure out with the data log that you have? Not really sure what to be looking at. Looking at the numbers from just a wide view, I see where your fuel pressure is low which can be a sign of either a plugged fuel filter, fuel pump starting to go bad, or a blockage in the fuel line itself. That was the only abnormality I could see. Granted, not sure what the G(x) and the other matching numbers are supposed to represent.
Old Mar 14, 2018 | 01:32 AM
Yeah, the fuel pump only works on one side. The low fuel light comes on and extinguishes on key on, but does not work with fuel consumption. Learned 3 times the hard way. So when it gets 100-80 miles (range) to empty, I fill up.
Had a P0455 & P0456 & reversed the gas cap seal, cleared & haven't returned. The log was the drive after clearing the codes. I'll attach pics of the "dials" I selected on torque app & got the above info for export.
Old Mar 14, 2018 | 04:35 AM
Thermo's Avatar
Veteran: Navy
dell, from what I can tell, you should be good. Other than the fuel pressure being a little low, all appears good to me. Just keep an eye on the CEL and see what happens.
AL NZ
Feb 8, 2018 03:58 AM
RobinGa
Nov 21, 2016 07:15 PM
spider
Sep 14, 2013 06:25 PM
patrickw813
Mar 3, 2010 08:11 PM
