Jag won't rev past 3000 revs
Old Nov 13, 2017 | 03:23 AM
Peter1987's Avatar
Default Jag won't rev past 3000 revs
Hi wonder if anyone can help before the car go to scrap I've took a reading with my obd
ive changed all 6 plugs to NGK
Here the reading
Old Nov 13, 2017 | 03:50 AM
Mark Murphy's Avatar
Which engine? when you changed the spark plugs, did you replace the inlet gaskets? also check the wiring to coils, maybe under airbox.
Old Nov 13, 2017 | 03:54 AM
Peter1987's Avatar
Hi my garage said the gasket will be fine just change the plugs. Know I can't get under my bonnet one side open the other side won't open
Old Nov 13, 2017 | 04:04 AM
The gaskets compress with age, then you get inlet leaks, and a bunch of codes, much like yours. have you got the bonnet open?
Old Nov 13, 2017 | 04:06 AM
Peter1987's Avatar
No can't get it open
