Jaguar x-type 2006 model petrol
Old Jan 15, 2015 | 06:44 AM
hemig's Avatar
Default Jaguar x-type 2006 model petrol
I have been experiencing a problem with my Jaguar X-Type (2006). I just had a minor service done (oil change, spark plugs). Subsequently, it has a slight jerk on start-up, and feels as if it is sucking in air. Once you drive it for a little while it is fine. Took it back to the garage and they cannot find any faults. On two occasions, when I put it into gear (reverse and drive) the "sucking in air " sound was louder. Back in "Park" it was better. Any suggestions?
Old Jan 15, 2015 | 10:48 AM
daxter1987's Avatar
You could try power braking it and see if a friend or you hear it while the other power brakes it. To power brake it apply the hand brake, step on the brake and put the car in drive, and pulse the accelerator without letting go of the brake.
If not you could also try this checklist: jaghelp.com: That pesky rough idle
Also get a code reader and check for faults to make sure you don't have any. Then look at the trims, see if they are close to 0% like they are suppose to. If they changed the spark plugs in the v6 they probably removed the intake manifold, did they put new seals?
rvdz
Dec 7, 2019 06:42 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
h4wk
Nov 27, 2015 05:10 PM
Dion Petty
Aug 30, 2015 01:00 PM
EastFalk
Aug 29, 2015 08:22 PM
