k van nuil
Old May 3, 2017 | 12:00 PM
k van nuil's Avatar
Default k van nuil
just been given an x type sport v6 ,been on owners drive for 3 years has not been started ,moved in all that time ,oil clean and correct level ,coolant ok ,was thinking should i crank engine over a few time with socket on crank shaft nut before trying to start , any advise most welcome
Old May 3, 2017 | 03:33 PM
Rchiv's Avatar
Hi and welcome to the forum. If it has been standing for that length of time I would crank it over just to prove that the engine has not seized. If it turns ok then you will need to use fresh fuel as almost certainly the old fuel will have deteriorated.
Also you will need to give it a really good inspection on bushes and also make sure the rear brakes have not seized on if the handbrake was engaged.
Tyres may have also deteriorated.
Roger
Daim
Jul 17, 2017 07:31 AM
racerxf12004
Apr 29, 2017 12:26 AM
NoScurdyJags
Apr 21, 2017 08:06 PM
