key fob
Old Aug 27, 2012 | 02:57 PM
Mark Lawrence's Avatar
Default key fob
hi folks, was wondering if anyone could help me. i have a 2002 xtype 2.5 sport. my key fob was a bit worse for then stopped working so i bought a new one, i programed it and it worked fine for a couple month then one day just stopped working, tried changing battery and re-programing but it wont work, i wondered if it was maybe a fuse or problem in the car.. any help would be much apreciated...thanks...mark
Old Aug 27, 2012 | 05:02 PM
astromorg's Avatar
Sounds like it could be the little flap over the ignition key hole - some graphite powder or just a spot of WD40 should free it up. The fob won't work if the car 'thinks' there's a key in the ignition! (That flap operates a switch as the key is put in or taken out)
Old Aug 27, 2012 | 11:13 PM
disguay's Avatar
Yep, if the car dings when the door is open with your lights off and key out, you've got a bad flap just like me... I'll have to try the graphite powder, thanks armstrong
Old Aug 28, 2012 | 01:11 PM
astromorg's Avatar
Who's this guy Armstrong butting in?!!
Astromorg was pleased to help though!!
Old Aug 31, 2012 | 01:36 PM
have looked at the flap, it seems ok. is there a posibility theres a fuse or something gone? where inside the car is the sensor for the remote locking?
Old Sep 13, 2012 | 03:15 PM
Default key
does anyone have any ideas? help would be much appreciated
Old Sep 14, 2012 | 12:07 PM
disguay's Avatar
hm... to me, the only thing that would explain it is if there are still keys in the ignition, or if your lights are on. Check fuses related to those two functions.
Old Sep 14, 2012 | 01:47 PM
Default key
thanks i will try that, do you know what fuses relate to them?
Old Sep 14, 2012 | 02:05 PM
Default key
when i have my key in ignition and open the door there is no "ding" noise. would this have anything to do with it?
Old Sep 20, 2012 | 01:06 PM
Default key
does anyone have any idea on this problem? its starting to drive me nuts
Old Sep 24, 2012 | 02:24 PM
WayneCountyBill's Avatar
Default Key Fob
Hi, Mark. I have a similar situation. I replaced the battery. I programmed the fob and it worked fine for a few months. Now it only unlocks the driver's door and locks all of the doors. I am going to try the battery again and see if that works. Other than that, there is not much I think that can be done, because you have tried everything else. Good luck and keep us posted.
Attached Thumbnails key fob-gedc1371.jpg   key fob-gedc1364.jpg   key fob-gedc1385.jpg
Old Oct 14, 2012 | 08:28 PM
GLH's Avatar
GLH
My fob would only unlock the drivers door until I cleaned the fob with a contact cleaner. The other fob would not work at all until cleaned.
philwarner
28
Jul 11, 2017 10:21 AM
redxk8
Sep 30, 2015 08:18 AM
Listers
Sep 30, 2015 07:45 AM
Jzar
Sep 27, 2015 02:55 PM
