Need help
Old Jun 7, 2020 | 09:08 AM
Antone Souza's Avatar
Default Need help
Need help new to this.. Dont know name of this.. Mine broke when changing coil and plugs. Thanks
Old Jun 7, 2020 | 02:01 PM
avern1's Avatar
It would be easier to help if we new what Model-year-engine you were working on. You need to add that info to your signature so the info will always be there. Assuming you are working on a 2.5 or 3.0 V-6 X-type the part you are probably looking for is shown below. The one in the picture looks like it is broken.
Old Jun 7, 2020 | 02:03 PM
avern1's Avatar
To remove the piece that inserts into the manifold is a trick. You press the outside ring against the manifold and gently pull the plastic tube out. To install simply insert.
Old Jun 7, 2020 | 07:12 PM
Thermo's Avatar
Veteran: Navy
Avern1, he is not after the brake booster line, he needs the vacuum line that attaches to the back of the intake manifold.
Antone, when I have broken that plastic tubing, I just get me some vacuum line and slid it over that tubing and used hose clamps to seal things up. I want to say I used some 1/4" ID vacuum line. It is something right in that neighborhood. I had some laying around in my garage.
TonyJ1977
Mar 4, 2020 08:43 PM
Lotusjag04
Jan 2, 2019 02:49 PM
