Need to know x-type low-gear shifting
Old Mar 8, 2012 | 12:14 AM
asaaidi's Avatar
Default Need to know x-type low-gear shifting
sorry for the constant questions. Im new to the ownership of a jaguar and this forum. My certified mechanic(brother-in-law, lol) told me to replace my shifter because it will not go out of park. I went and bought a shifter and when it came my brother in law looked at it and said its missing a part for the low gears(4,3,2). I returned it and got another one and it has the same problem. I searched and all the ones that i found had the same part missing. I took it to the dealer and asked them if there should be a part that needs to be there and they said yes, but they only sell the whole unit. I figured maybe the shifter just comes that way because all of the shifters i came in contact with had the same problem. I included pictures below(attachments) can anyone tell me how the low-hear shifters work? Do they work electrically, without the pawl? Or is there really a part missing? Please let me know, your help is greatly appreciated. And if someone has pictures please include it, thank you soo much
p.s i checked the bottom of the shifter handle and did not see any marking of any kind it looks like new no part missing please advice thank you
File Type: docx
Old Mar 8, 2012 | 11:53 AM
astromorg's Avatar
Default X Type Auto Gear Shifter
Before your mechanic recommended a new shifter, did he confirm that the problem was not just one of the following 'easier' possibilities/solutions?
'Not-in-Park' microswitch in J Gate failed (Easy/cheap to fix!)
Gearshift interlock solenoid in J Gate failure
Brake light switch operating correctly (Two switches in one)
And, without wishing to sound patronising, pressing brake pedal to release gear shifter! It has been known!!
Old Mar 8, 2012 | 12:27 PM
asaaidi's Avatar
he worked hard on it it was cold and mayby he want to get even with me and my sister he is my brother-in-law cheap labor he did not know at that time that car has a bad ecm engine computer we got it for $50 which is not bad i just want to know what part i am missing on that shifter???
Old Mar 8, 2012 | 12:44 PM
Brutal's Avatar
It has a stem and ball on the bottom through that lever that when you slide across to 4 3 2 in engages. Thats mismanufactured. What did you Pay and where did you get it
Old Mar 8, 2012 | 01:22 PM
asaaidi's Avatar
he still has one for $50
Middleton Auto Parts
33215 Groesbeck Highway Fraser, Michigan 48026 1 586 296 1510
1 800 334 5137
so how dose the shifter work on 4,3,2 or is it just for looks the stick dose not enguage the plaw at all please let me know
Old Mar 8, 2012 | 09:22 PM
Gold_04_X-Type's Avatar
Originally Posted by asaaidi
1 800 334 5137
I used to live in Fraser!
Anyway, there is a hall effect sensor (magnetic) that senses when the shifter is moved left and right between D to 4. This results in no cable movement when shifting between those two positions, because the shifter is being moved from one cable (P to D) to a second cable (4 - 2). So once the shifter is in 4 you should be see that second arm move back and forth when sliding between 4 and 2.
Old Mar 9, 2012 | 12:05 PM
asaaidi's Avatar
Cool shifter low gear
thank you so so much now i can install it . have a nice weekend thank you again
ricwel
Jun 23, 2023 05:14 PM
ryan_border
Dec 23, 2015 04:27 PM
vwbusbits
Oct 13, 2015 03:43 AM
danke
Oct 3, 2015 09:31 PM
vwbusbits
Oct 1, 2015 01:17 AM
