New Wheels?
Old Jul 24, 2012 | 07:38 AM
RomanEmpire's Avatar
Default New Wheels?
My x type has 17" low-profile tires. The rid is rather bumpy with these ties and I've been thinking about going with a standard "balloon tire or high profile. Would I need to get new wheel rims - say a 15", or can I fit a high profile tire to the 17" ones that are already on the car. After all is said and done, will I get a smoother ride? What's the point of the low-profile tire anyway? Thanks for any help!
Old Jul 24, 2012 | 07:47 AM
pab's Avatar
pab
15" or 16" would certainly give you a cushier ride. I would suggest going to tirerack and checking out tire options. You can identify your car and let them identify suitable tires in various sizes. Any tire with the same diameter as you current tire will work, the profile will simply be taller for the smaller sized wheels.
Jaguar: Grace, Pace, and Space - Sir William Lyons
Old Jul 24, 2012 | 07:51 AM
RudyF6's Avatar
Different tires might help - I have 225/40/18's and went from a very stiff summer performance tire (Toyo Proxes 4) that cornered very well, but gave a somewhat harsh ride. Just recently I changed to a performance all-season tire (Continental Extreme Contact DWS). I gave up some cornering grip vs. the Toyo, but gained a much nicer ride quality on the highway - a compromise I'm very happy with. The ride quality of the Continental is as comfortable as the 205/55/16's that my X came with.
Default Follow up
Hi Pab...The front end of my x type rattles and cluncks like the dickens! And the ride is rough with the 17" low-profile tires. Where do I begin to try and smooth out the ride and eliminate the noise?
Old Jul 24, 2012 | 07:54 AM
pab's Avatar
pab
I'd say your problems extend beyond rough ride from low profile tires...
You should do a comprehensive check of your front suspension, you may have worn ball joints, or strut bushings, or some other problem.
I'd suggest taking it to an alignment shop and letting the tech have a look.
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
scooternva
19
Oct 27, 2015 02:14 PM
DustysSon
Sep 13, 2015 04:17 AM
lickahotskillet
Sep 11, 2015 07:54 PM
