No power
Old Jul 12, 2023 | 11:05 AM
Jeremyjack's Avatar
Default No power
Hey guys I was driving yesterday and ended up hitting a center median making all four wheels hit up on 6 inch curb , Was moving at about 25 mph and the car immediately shut down loosing power to engine, transmission, windows . All lights work including the dash and radio .. I have over 20 dtc's and I believe the theft deterrent system and fuel shutoff happened . Majority is the can bus evaporative system . How can I get power to my windows so they will roll up and also do a hard computer reset so it'll drive and start ?
Old Jul 12, 2023 | 05:12 PM
h2o2steam's Avatar
Have you checked your inertia switch in the lower A pillar footwell?
That sort of abrupt shock could have very well tripped it and disabled the car.
Old Jul 12, 2023 | 05:18 PM
Jeremyjack's Avatar
Yeah it was tripped it's all fixed now thank you !!
Old Jul 12, 2023 | 06:18 PM
h2o2steam's Avatar
You might want to be wary of a possible bent rim or at the very least you may have knocked the wheel alignment out.
Visually check the rim to see if it has any impact deformity.
When you are next driving it, see if the car is now tending to pull left or right since the kerb incident - wheel alignment out if it is.
Also check to see if you have picked up a vibration in the car or steering wheel as you get the opportunity to bring the car up to freeway speeds - could indicate a bent or crushed rim.
dean1964
Nov 14, 2022 12:55 PM
vidx3m
May 29, 2020 09:58 AM
jeremys
May 27, 2015 06:43 PM
Owsley9
XJ XJ12 ( X305 )
Jan 7, 2015 10:55 AM
