Oxygen sensor
Old Nov 24, 2019 | 08:53 PM
Zalan's Avatar
Default Oxygen sensor
X-type 2002 2.5 L
Code reader read P1647. This is bank 2 (nearest radiator) upstream oxygen sensor (on front exhaust manifold).
I replaced it with a generic 'fits x-type' sensor.
After clearing the code, it came back.
So...Is there something wrong with using generic sensors?
Experiences please.
Old Nov 24, 2019 | 09:51 PM
Dell Gailey's Avatar
Yes, many, many, many threads on generic (usually internet Asian buys) not working, sometimes even after replacing them multiple times. You need to use OEM ones, period!
Old Nov 25, 2019 | 05:30 AM
Thermo's Avatar
Veteran: Navy
I replaced the ones on my car with a brand name maker (want to say it was Bosch). The big things to keep in mind is that 1) it is from a major manufacturer (preferably Denso, Bosch, or other equivalent group), and 2) the sensor has the wires already made up and not having you splice into the old plug. I can't tell you how many horror stories I have heard from people getting the generic sensors and then having fits trying to get the wiring to work.
The other problem that I have seen is that you have oxygen sensors and then you have air-to-fuel sensors. The upstream sensors are air-to-fuel. If you look on the plug casing, you should note that the plastic is either gray or black (as I recall). If memory serves me correct, the gray is the air-to-fuel sensor, the black is the oxygen sensor. While they perform very similar functions, they are just that little bit different and will really raise hell. That would be the other thing I would verify.
Old Nov 25, 2019 | 11:54 AM
Zalan's Avatar
Default You get what you pay for.
Thanks guys.
I have requested to return the sensor and I just noticed that a refund has been issued. $US 38 what do I expect for that?
I may try a Denso or Bosch which are still a good bit cheaper ($US100) but I am tempted to shell out for the OEM.(on-line $US 180 dealer price $US 270)
I do see the difference between Air/fuel and Oxygen sensors but I get mentally lazy. The one I tried was listed as Air/fuel sensor.
Traveller
Feb 27, 2020 10:13 PM
GMWebster
Aug 8, 2017 02:52 PM
Rogelio Serrano
Nov 22, 2016 02:47 PM
FRGIII2014
Mar 20, 2015 04:22 PM
Red October
Feb 9, 2015 06:32 AM
