P-0121....p-1111
Old Mar 16, 2013 | 07:25 AM
04JagXtype's Avatar
Default P-0121....p-1111
Those are the codes in currently showing. I popped the hood and the small black throttle control box was "buzzing " unpluged it waited a few seconds plugged back in. Light went away. Can this be my Gear box/ Engine system fault problem?
Old Mar 16, 2013 | 07:30 AM
steveinfrance's Avatar
P1111 is 'tests completed', not a fault.
P0121 is probably TPS related. Almost certainly cleaning the TPS connector will fix it.
Old Mar 16, 2013 | 07:58 AM
04JagXtype's Avatar
Thats great news. Wow something so small can cause great issue. Had me going bonkers.
Old Mar 20, 2013 | 11:18 AM
DawgsXtype's Avatar
04Jag,
Just went through the "restricive performance" mode shut down process drivetrain warning light X2. Talked it over with Thermo and was able to pinpoint a filthy throttle body disk. A good cleaning with TB cleaner wiping down the surfaces I could get to, not difficult. The problem is gone and I have noticed smoother starts and idle + a bit better fuel mileage. It would be nice if the computer would read TB issue instead of drivetrain. Good luck
Old Mar 21, 2013 | 07:08 AM
04JagXtype's Avatar
After i unplugged and cleaned the connection diodes its been good to go. When the weather thawes i will clean the TB plate
