Rear differential rebuild?
Old Feb 19, 2021 | 01:11 AM
Jagboi64's Avatar
Default Rear differential rebuild?
I am in the process of a driveline overhaul, partly to eliminate the cold weather whine the X Types are known for. At the moment I have the transfer case and driveshaft out of the car and while I have easy access I checked the freeplay of the rear differential pinion hub. It moves way more than a typical differential should, so to me that says the backlash is out of spec.I also have a whine on smooth pavement that comes and goes as power is applied or removed at constant speed, another indicator of a diff out of spec.
Is there a manual or instructions for rebuilding the differential? I see that Jaguar does not sell any internal parts, just a whole unit exchange. I've rebuilt an XJS differential before, so have the tools to do it, but specs and clearances would be useful.
Old Feb 19, 2021 | 06:11 PM
dennis black's Avatar
20 Year Member
its not worth rebuilding ,if you open your diff you will find sludge , when it gets cold it takes a while for the oil to get warm , ive got the sludge out of mine and put royal purple in ,whine gone
Old Feb 19, 2021 | 06:52 PM
Jagboi64's Avatar
I have changed the oil - made no difference.
Old Feb 20, 2021 | 04:02 PM
20 Year Member
they are so cheap you can get one in ct for $70 when i put royal purple in mine noise instantly stoped for the lassst 6 winters, but your issue maybe differant
Old Feb 20, 2021 | 07:14 PM
Dell Gailey's Avatar
It sounds more like a carrier bearing problem = i.e. "the cold weather whine X's are known for".
Old Feb 21, 2021 | 12:16 AM
Jagboi64's Avatar
I have two different noises. I have the typical cold weather whine, plus a much more subtle whine. The cold weather noise is speed dependant, and generally doesn't happen when the temperature is above freezing. It's right at 40 km/h and 70 km/h. The more subtle noise occurs at any temperature and roadspeed and I can make it come and go with application of throttle at a constant speed.
All the other Jaguar differentials I have from XJ's have an almost imperceptible amount of movement when I turn the pinion shaft before the output shafts move. Essentially zero slop in the gears. When I have the driveshaft out of the X Type tonight I could turn the pinion about 1/8" at the hub with no movement of the output shafts. I could also hear a clunk as I moved the pinion back and forth when it contacted the teeth of the crown wheel I'm assuming. To me it feels like excessive backlash. The transfer case is essentially a differential, and it is like the XJ differentials in terms of backlash - essentially no slop in the gear mesh.
Louie71
Jan 7, 2021 08:55 PM
xalty
Nov 30, 2020 10:22 AM
bojangles
Nov 24, 2015 12:45 PM
2jag
May 30, 2013 11:44 AM
davis1d0
Sep 25, 2011 07:13 AM
