Rear wheel knuckle
Huh?
Thanks for your reply but it has
nothing to do with what I asked.
Of course the rear trailing arms contain no moving parts.
My question was about the outer rear lower trailing arm bushing.
The lower rear trailing arm has an inboard mount with a pressed in bushing.The outer end is held in place by a bolt which goes thru a bushing in the wheel knuckle (the part that holds the hub/wheel bearing).
My question was simply: is that knuckle bushing pressed in or a loose fit, i.e. can it be removed without a hydraulic press?
The knuckle bushings on each side of my car are bad.
