Recommendations please
Heater stopped working on jag 2004 X-Type. Blows air but is cold. What is likely cause?
Welcome to the forum jdm2004,
I've moved your question from Jaguar Forums Feedback & Suggestion Center to X-Type forum. Members here with the same model will be able to help.
Have you checked your coolant level? If it's low that could be the easiest answer. However if you haven't kept up with reasonable coolant services I'd say your heater core is blocked. There's lots of DIY repair videos on YouTube. Here's one:
https://www.youtube.com/watch?v=ACQusEZw90g
If your coolant has been low you may also have an air trapped in the heater core.
https://www.jaguarforums.com/forum/x...system-106516/
Sean W
Dec 1, 2016 09:16 AM
