Removal of Sun Visor/Vanity Mirror assembly
Howdy folks,
Can someone please help me with a procedure to completely remove the Sun Shade / Vanity Mirror Unit - from the roof interior?
The Swivel & Pivot Arm (fixing not so obvious) is what I need to remove.
All help and suggestions much appreciated.
The visor has a plastic cover at the point where the arm is mounted to the roof. You remove the cover by gently prying off. Beneath it is 3 screws that you remove and then pull the the unit out slowly and unplug the power cable. Installation is the reverse.
Hi avern,
Thanks for your guidance and assistance....... I found and removed the split cover which exposes the three VX20 Torx screws...... the rest was as you said.
Thanks again,
Thanks again,
