Replacing the Jaguar tape cassette with the Jaguar CD player on X-Type 3.0L SE 4dr
Hi,
My X-Type 3.0L SE 4dr (June 2001) came with a tape cassette instead of a CD player (at the front). Is it an easy job to replace the tape cassette with the Jaguar CD player (if I buy a Jaguar CD player on eBay)?
Is it easy to obtain the unlocking code for the CD player from Jaguar (if the one I buy does not come with the unlocking code), please?
Thanks in advance,
Alexandre
Thanks in advance,
Alexandre
The CD player is a fairly old device, and it only supports traditional audio CDs (the sort where you can have max. 60-70 minutes of music) so you can't use data CDs (on which you could drop 100 mp3 files with no regard to their total duration).
If I were you, I'd give serious consideration to doing this mod instead:
How-To: DIY headunit hack for AUX-IN (on tape deck).
Basically, you solder a few leads into the cassette player, and then you have a direct line-in available with CD-level quality that you can plug any sort of sound source into. I for example have hidden an mp3 player inside the ashtray with a charger. The player starts and stops with the car, and when the ashtray lid is closed everything looks unmodified.
I bought a cheap & cheerful USB , MP3 transmitter . Got a memory stick with my music on , plug into lighter socket & car radio ariel picks up transmission & plays through standard radio. Bit basic, but suits me as I'm partially deaf in one ear so volume is better than quality to me ....
I did exactly this. Bought a used CD on eBay and it was an easy replacement. Plug and play.
I have an ACM so I had to get the CDC button activated. It's a quick affair done by my local Jag guy.
Also there was no security code. I understand that US cars don't have security codes.
picking up a car on Tues with a sat nav and cassette combo. I'm unsure if the nav and player are one, or if I can buy a cd player separately. Seen some with 6cd changers but have a cassette port on the dash; how does that work? I want to upgrade to a CD player, but not lose or tamper with my sat nav. Any one got any advice??
Just an update: I've finally managed to get a car electrician to fit the Jaguar CD player. Old went the cassette player, new came the CD player. I now have a CD player at the front... but no clock. Somehow, everything else (satnav, phone, radio etc.) works, but no more option for the clock. I will ask the car electrician to take another look at the wiring. I'm just worried that I may lose satnav in the process.
A further update: I've managed to find the clock! I've applied the Phone+Menu way (1971 Diag PIN). I've updated the s/w to the latest 9.03 version. As a result, I got the clock back. But now my satnav GPS thinks it's in Belgium! How do I change to UK, please? I've done a manual set up, an automatic set up... all sorts. However, the satnav map thinks it's still in Belgium. Any reasonable ideas, please? Thanks in advance!
Jaguar Forums Editor
Jaguar Press release
Aug 27, 2015 03:18 AM
