S button
Old Jul 5, 2009 | 02:54 PM
Jessy's Avatar
Default S button
recently i noticed that my red light doesnt come on anymore when i press the S button. Is there any way that i can replace the light? is it hard?
Old Jul 5, 2009 | 05:44 PM
Jaggyx's Avatar
i have no idea, but honeslty does this little button do anything or is it just for show?
Old Jul 5, 2009 | 07:04 PM
Sevren's Avatar
Yes, that's what the "S" stands for : Show.
Seriously, this is the Sport Mode button. It makes your automatic transmission shift at a higher RPM. If your light does not turn on anymore, it may be a sign that there is a problem with your car that prevents Sport Mode from functionning correctly, and not simply that the light needs to be replaced.
Use the forum search engine, I believe I recall someone having similar trouble not too long ago.
Old Jul 6, 2009 | 01:56 PM
Jaggyx's Avatar
oh alright I was just making sure, thanks sevren.
Old Sep 8, 2009 | 08:59 PM
jvegas's Avatar
bump.....
my 05 x-type had an issue where the battery went dead last week. The check engine light came on so I took the car in and had the codes read. it was p1603 (i think). that meant the battery was disconnected while the motor was running. (i think)
Now the sport button will not work. This drives me nuts because I always drive in "S" mode. I no longer have a check engine light but the button will not put the car in sport mode!
what should I do? what do I check?
Old Sep 8, 2009 | 10:01 PM
Wankel's Avatar
It definitely makes a difference on my 2.5, but its not worth beating on it like that. On the freeway when im in S mode it literally takes it to 7k redline and takes quite some time for that final shift with no real power behind it. I find that the car scoots along much better with it off because for it to be effective you have to have your foot to the floor.
Old Sep 8, 2009 | 10:07 PM
Disco stu55's Avatar
agreed, we realluy should have got the 3.0l, didn't knw it existed til after i got it, should have done more research
Old Sep 16, 2009 | 11:20 PM
jvegas's Avatar
anyone?? what happened to this place? 1 year ago there would be a sure answer to my question?
Old Sep 16, 2009 | 11:40 PM
Jessy's Avatar
ooo wow this post was mighty old. Sorry Jvegas ive gotten nothing but NOW My S button doesnt turn off hahaha boy ohhh boy m i having a ball with my cat however I dont drive her anymore thats why i havent posted or been on the forum in a while. I go to Uni now and take the bus its faster and beats the rush because of the bus lanes only take the cat out of the garage on friday nights and park her in on sunday night...now my weekday driver is a Buick rendevous...looking for a pickup truck or even a beater.
Old Sep 28, 2009 | 08:45 PM
jvegas's Avatar
UPDATE; I noticed the car was cranking a little longer then it used to before the engine would kick over and start. I replaced the battery and this fixed my "S" button issue. I guess the car tripped into some sort of "safe" mode. this might help others with the same issue.
Old Sep 29, 2009 | 09:25 AM
paulxtype's Avatar
Good info jvegas. Thanks for the update.
PolkNole
Oct 21, 2025 02:22 PM
ricwel
Jun 23, 2023 05:14 PM
philwarner
28
Jul 11, 2017 10:21 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
apolloxk8
Sep 28, 2015 08:27 PM
