Seeking A/C help.
Old Jul 8, 2015 | 04:02 PM
innzane's Avatar
Default Seeking A/C help.
2002 3.0 Automatic
#1 Is the compressor the one all the way at the front bottom of the engine, below the alternator?
#2 If that is it, clutch not engaged the front plate does not move, but if the clutch is engaged the front plate spins, correct?
#3 If correct, I get no spin, is there anything to check on the compressor it's self?
I have no cool air at all, car does not act like compressor is engaging.
I have checked the stuck vent issue, all clear.
Blower works fine.
I have checked the A/C ECU fuse inside, good
Under hood I checked fuses
F10 F23 F36
Fuse at relays 5&6 is good, I get 12V on 2 terminals in the R6 slot(to battery ground)
Have swapped relays.
I do not have windshield washer pump working either.
Any tips, advice?
Old Jul 8, 2015 | 07:33 PM
DPK's Avatar
DPK
#1..YES
#2..YES
#3..Clutch has a two wire connection going to it, Pop the connector and measure to see if 12Vdc is present when calling for cooling..if YES, then the electrical clutch is bad...If NO then you may have; a) low refrigerant level to almost nothing or; b) a low pressure switch is faulty (open), not sensing refrigerant pressure in the system.
Old Jul 8, 2015 | 10:16 PM
innzane's Avatar
Awesome, thx for the input.
I will check it out.
Old Jul 9, 2015 | 08:29 AM
Thermo's Avatar
Veteran: Navy
DPK is on the right track.
Poet
Feb 7, 2025 02:18 PM
Paora
Feb 4, 2021 12:36 AM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
rocket1lf
Sep 29, 2015 09:16 AM
