If I recall the plug is steel. This will allow you to weld on a nut onto it. If the plug is aluminum like the pan you can still weld something onto it just not as EZ.
Remember to disconnect the battery before doing any welding on a car.
Use Vice-grips (a locking wrench) to remove the drain bolt, and replace with a new bolt and washer - and do not over tighten!
The plug was definitely overtorqued by the previous owner. I'm considering taking the engine out because the sump is leaking anyway and I am concerned about the state of the right chain tensioner.
I wasn't joking about the stilson, but a small one about 12" would work or a judicious blow with a hammer and chisel might work.
I don't have any confidence in screw extractors based on experience.
the 18 inch stilson did it! Somebody put some kind of glue as a sealant!
Changed the oil so I can test if the rattling is still there on startup then I'll be changing the oil pan gasket.
