Shane
Old Sep 21, 2014 | 09:34 AM
shanewood's Avatar
Default Shane
I have a 2004 2ltr Diesel x type and having trouble with the windscreen washers. The pressure seems very low. the drivers side manages to just about spray, but nothing from the passenger side unless I hold a finger over the drivers side jets, then the passenger side works. I have blown out the jets etc but it is no better. I think the top part of the washer bottle may have a leak, not sure if this would cause low pressure. Any Ideas ??
Old Sep 21, 2014 | 10:06 AM
billbjork's Avatar
carefully unhook the nozzle from the hood(bonnet)pull the hose off the nozzle, take a needle and clean out the orifice then use air pressure to blow from the top down (backwards). Each side has a restricter built into the line to equalize the pressure, you can blow out that too. I removed both restricters from mine and it works fine. If the spray isn't hitting the window correctly you can use a needle to readjust the little orifice till it goes where you want. They move hard and seem like you can't move them but you can.
sporty501
17
Jun 19, 2015 05:12 PM
SonnyJag
Jan 5, 2015 05:06 AM
ShaneClara
Nov 23, 2014 11:24 AM
thatchers98
Aug 14, 2014 07:20 AM
bandit788
Oct 21, 2012 07:21 PM
