Squeaking/chirping from front noise when driving
Old Jul 22, 2018 | 10:25 AM
Dandy01's Avatar
Default Squeaking/chirping from front noise when driving
Hi,
I have an X type 2004 2.5 v6, which has developed a squeaking/chirping noise which seems to be coming from the front of vehicle left side. only occurs when driving and can only be heard with the windows down and quite load in built-up areas.
any ideas
Old Jul 22, 2018 | 04:40 PM
Dell Gailey's Avatar
Number 1 cause is =
after these, it could be drop links (I replaced both while in there), then next is front stabilizer bar (bushes) lastly the strut (or bearing bush).
Old Jul 22, 2018 | 09:05 PM
dwclapp's Avatar
Dandy: If you have wheel ramps, try this...… drive the front wheels onto the ramps, lie on your back under the front of the car, and with gloved hands (14 years of road grime down there), push up and pull down on the front subframe and suspension to rock the car up and down. You don't have to be Arnold Schwarzenegger, just rock the front suspension a 1/4 inch or so to make it squeak. Keep grabbing different parts of the suspension as you rock it up and down, and eventually, hopefully you'll grab a suspension member that vibrates in your hand with every squeak.
davetibbs
Sep 8, 2014 02:35 PM
jagosaurus
Jul 19, 2013 12:58 AM
stevepaa
Nov 29, 2012 02:10 AM
Louenigma
General Tech Help
Sep 22, 2012 05:17 PM
adam12hicks
Jan 24, 2009 01:49 PM
