sub audio wiring
Old Apr 13, 2013 | 12:07 PM
jaguar 03's Avatar
Default sub audio wiring
hi could anyone help me please
i have a 2003 x type,i just purchased a alpine bass box and amp for under the back shelf but there is no wireing loom in the car,does anyone know how i can wire this in,cheers.colin
Old Apr 14, 2013 | 04:12 AM
steveinfrance's Avatar
Hi and welcome.
I moved this post to your car technical section where you'll get the best help.
Old Apr 14, 2013 | 07:40 AM
Yaguareté's Avatar
Hi Jaguar 03 Welcome to the forum.
As far as the sound goes, do you have the premium sound system? If so what I did to add a little extra bass was cut the input wire going to the 1.5 subs(Second sub is a passive driver) in the rear deck and added a low line converter. There's about 10 long screws to remove the cover under the rear deck to get to the inclosed stock subs.
Xscorpion SC-LC07 (LC-07) High to Low Compact Line Output Converter
I wired the remote line from the front astray.
Also ran a power wire from the battery.
I went with a low line converter because I have the navigation system and didn't want to install an aftermarket head unit. The only thing I will mention on this is you need a good amp with adjustments to get the volume level right. If not you can get a sound processor. Hifonics MX-3 (mx3) Bass Controller for use with Aftermarket
Old Apr 14, 2013 | 07:42 AM
Thermo's Avatar
Veteran: Navy
Colin, wiring up the sub may be easy, it may not be. The question comes down to whether you have the standard radio or if you have the premium (ie, SAT/NAV) radio. The standard radio does not have any sort of "sub wires" in the car. The premium does and as I recall, the plug is normally tucked to the left side of the trunk/boot (as you are looking into the trunk). So, if you don't have a plug there, then you may be out of luck.
Just for reference, the plug for the factory sub is an 14 pin plug with 10 wires in it. Probably not what you are looking for without knowing what you should be expecting.
If you need more help, let me know. We will help you out and get you the info you need.
Old Apr 14, 2013 | 10:40 AM
jaguar 03's Avatar
hi thanks for the reply,i have the sat nav/touch screen stereo version,i looked in the boot had the rear shelf out but have no plug anywhere so i must not have the premium wireing.
cheers.colin
Old Apr 14, 2013 | 10:44 AM
jaguar 03's Avatar
cheers chris no plug to be found,i have the satnav/touchscreen stereo in the dash,i wanted to fit the premium subs,amp enclosure under the shelf and keep me origional stereo for obvious reasons,so not sure what to do now
Rivguy
Nov 13, 2022 02:55 AM
dstary
Sep 19, 2015 09:47 AM
R-Sport
Sep 18, 2015 01:44 PM
'05 Gold XJ8L VDP
Sep 18, 2015 07:15 AM
pjanca
Sep 16, 2015 08:07 PM
