Subwoofer Removal - Estate Wagon
Old Mar 10, 2019 | 04:27 PM
max224's Avatar
Default Subwoofer Removal - Estate Wagon
Has anyone been able to remove the subwoofer from the rear panel of an Estate Wagon? I removed every screw and bolt I could find and it still won't budge. Seems to be caught on the top of the panel the speaker is installed in.
Thanks.
Old Mar 10, 2019 | 05:26 PM
Dell Gailey's Avatar
If it is like the first year model sedan, the "subwoofer" is actually a one piece unit.
https://www.jaguarforums.com/forum/x...lifier-212542/
Old Mar 10, 2019 | 08:54 PM
max224's Avatar
Hi Dell,
Thanks for responding. The subwoofer appears to be in a one-piece housing that will likely require the removal of some trim (I've already removed all of the screws and bolts I could find and it's still not moving). Unfortunately, the subwoofer makes changing the reverse light bulb difficult, if not impossible (and I have the scratches and cuts to prove it). This is my 6th Jaguar, so you would think that I would be used to problems like this. It just makes me crazy that you can't perform a routine task like changing a light bulb without taking pieces of the car apart.
Maeflower
Feb 16, 2018 10:17 AM
lderobertis
Apr 3, 2017 09:31 AM
Suaro
XF (X260)
Feb 27, 2017 08:08 PM
TreVoRTasmin
Aug 27, 2014 05:50 PM
mycaptainchris
Oct 2, 2010 03:39 AM
