Thermostat housing o-ring?
Old Jan 31, 2021 | 09:43 PM
BlownKitty's Avatar
Default Thermostat housing o-ring?
While under one of our X-Types today I noticed a very minor coolant leak at the thermostat housing and I'm going to guess that it's likely coming from the flange.
Does anyone have the part# (OEM, Dorman, etc.) for the o-ring? It appear that Jaguar wants you to buy the upper radiator hose assembly (that'll be the day that I spend $100+ to repair something that an o-ring or RTV will fix!).
TIA
Old Jan 31, 2021 | 10:38 PM
TonyJ1977's Avatar
O ring for the thermostat housing ? Or the o ring that goes between the housing and the motor ?
Old Jan 31, 2021 | 10:41 PM
TonyJ1977's Avatar
Old Jan 31, 2021 | 11:33 PM
avern1's Avatar
O-ring failure is a very rare occurrence with the cooling systems components. Unless it was originally installed incorrectly or the fasteners have come loose it is unusual.
Most likely you have a crack in one of the components. The only way to isolate is to due a cold pressure test of the system.
Old Feb 1, 2021 | 09:50 AM
BlownKitty's Avatar
Thanks guys, I'm thinking that it's #9 Thermostat Housing to Cylinder Head Seal.
It could be that the bolts have loosened, I'll snug them up and see what happens.
Old Feb 1, 2021 | 11:25 PM
watto700's Avatar
G'day Blown Kitty,
What I would do is hose off all avidence of leaking coolant and then drive the car for a while and have a good look around under the hood particularly around the front of the engine to determine where the leak actually is. In my experience it is unlikely to be a dodgy 'O' ring or loosened bolts.
When my car leaked it was a cracked fitting with leaking coolant running down onto the thermostat housing.This fitting is as Jaguar call it 'Top Radiator Hose' or P/N C2S43430 or # 7 in the above diagram. It is the 'T' piece that cracks and leaks but you can't just buy that piece separately it comes with several pieces including a thermostat.
If it is the 'T' piece you may be able to repair it with some sort of epoxy but I have never had any luck with this sort of repair as the internal pressure of the cooling system eventually forces the epoxy loose and the leak is still there.
When I did my repair I bought the whole thing, as there is no choice, and replaced the lot and have had no problem since.
Cheers,
Jeff.
Old Feb 2, 2021 | 01:06 PM
BlownKitty's Avatar
Originally Posted by watto700
G'day Blown Kitty,
Cheers,
Jeff.
Thanks Jeff,
I'll take a closer look around the area, I only discovered the leak while replacing the #2 bank upstream o2 sensor (and that was fun..).
Pale340
Feb 14, 2017 02:22 PM
BlackKat
Nov 25, 2015 10:04 PM
mikeeadyjr
Sep 3, 2014 12:31 PM
kenncl
Apr 22, 2012 06:47 PM
Dirk Bailey
Dec 8, 2010 08:10 PM
